Collaboration Between Revit 2015 & Inventor 2015
2 REPLIES 2
LuomaC05925
231 Views, 2 Replies
Just upgraded both Revit and Inventor to 2015 and heard that now the two programs can work together for example, in revit you would create your 3D model and then pull 2D shop drawings from the model, then you can, in a way, link your revit model to inventor where you use that same 3D model to create the fabrication drawings. Is this still possible and if so whats the proper sequence to do so?
2 REPLIES 2
mikako_harada
in reply to: LuomaC05925
Hi Luoma,
Looks like this is a product side question rather than API.  I'm going to move this to the product forum.
In a mean time, if you can point to the source of information, it might help product team to understand the feature you are asking.
Mikako Harada
Developer Technical Services
LuomaC05925
in reply to: mikako_harada
I believe i heard this information from a Autodesk product supplier/seller.
Rail Community
