Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Choice to show/hide Temporary Dimensions when selecting elements
2 REPLIES 2
Santiago.Diaz
1268 Views, 2 Replies
When I create a line in a Revit family, and then select it, Revit shows me temporary dimensions.
I googled whether I have the choice to see them or not when selecting lines, because I consider the dims to be distracting.
This is simply a personal preference. I realize that many folks out there appreciate these dims. I just want the option to see them only when I choose to.
In another subject on this discussion group, the answer is that this is not an available preference in Revit.
Would anyone happen to know whether this is possible via the API?
Thanks in advance!
2 REPLIES 2
Joe.Ye
in reply to: Santiago.Diaz
Hi Santiago,
I don't think Revit expose the UI Setting or API to control the visibility of the temporary dimension.
Via the Revit.INI, users can control the appearance of the temporary dimension, however cannot control its visibility.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
Santiago.Diaz
in reply to: Joe.Ye
Thanks Joe
Rail Community
