Revit API
Distinguished Contributor
7 Kudos
Post 1 of 2
Change the level of an element
405 Views, 1 Replies
11-21-2012 07:25 AM
How can I change the level of an element? Level property is read-only...
There is a trick or a hidden method somewhere?
instead of setting the level *property*, you could try to set the level *parameter*.
Depending on the type and category of the element you want to modify, you could set the BuiltInParameter.FAMILY_LEVEL_PARAM (for FamilyInstances), for example.
Use RevitLookup to get the level parameters for other kinds of elements.
Level params usually are set with an ElementId:
http://thebuildingcoder.typepad.com/blog/2011/01/family-instance-missing-level-property.html
Best regards,
Revitalizer
30 Kudos
Post 2 of 2
Re: Change the level of an element
11-21-2012 07:57 AM in reply to: FRFR1426
Best regards,
Revitalizer
