Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Change Revit User Name
5 REPLIES 5
Moustafa_K
1422 Views, 5 Replies
Is there an access to change the username of the document via API?
Moustafa Khalil
5 REPLIES 5
Dale.Bartlett
in reply to: Moustafa_K
My understnding is that this property is read only.
From SDK help:
BasicFileInfo..::..Username Property
BasicFileInfo Class
Returns the username.
Namespace: Autodesk.Revit.DB
C#
public string Username { get; }
______________
Yes, I'm Satoshi.
Which leads me to my next question:
How to return the Revit Username?
<code>
BasicFileInfo bfi = new BasicFileInfo();
return bfi.Username;
</code>
Is not correct: "no constructors defined"
Thanks, Dale
______________
Yes, I'm Satoshi.
Revitalizer
in reply to: Dale.Bartlett
UIApplication.Application.Username
Rudolf Honke
Software Developer
Mensch und Maschine
arnostlobel
Hello Dale,
It looks like the only method to get an instance of BasicFileInfo is static BasicFileInfo.Extract. Please note it does not work with an open document. It takes a path of a file on disk.
I do agree the documentation for the needs BasicFileInfo class to be improved. I have created a task for the responsible development team to update the documentation. Thank you for bringing this problem to our attention.
Arnošt Löbel
Hi Autodesk,
Please enable setting the Application.Username property in a future release.
Harry
Rail Community
