Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Change ActiveView
3 REPLIES 3
7414 Views, 3 Replies
Change ActiveView
Does anyone know how to change the ActiveView?
Bernie
3 REPLIES 3
jeremytammik
Dear Bernie,
This can be solved by RTFM...
Looking at the Revit API help file RevitAPI.chm, there are two separate ActiveView properties listed, on the (DB) Document and the UIDocument classes.
The former has only a getter. The latter offers a setter as well:
UIDocumen.ActiveView Property
The currently active view of the currently active document.
This property is applicable to the currently active document only. Returns null if this document doesn't represent the active document. The active view can only be changed when:
  • There is no open transaction.
  • IsModifiable is false.
  • IsReadOnly is false.
  • ViewActivating, ViewActivated, and any pre-action of events (such as DocumentSaving or DocumentClosingevents) are not being handled.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
arnostlobel
in reply to: jeremytammik
Just a side note: I do not recommend using the Document.ActiveView getter - it is an obsolete property that will likely go away at some point in the future. Please always use the ActiveView property on the UIDocument class like Jeremy suggests.
Arnošt Löbel
@arnostlobelIs there any further information on the obsolescence of Document.ActiveView? We have 2021, the property is still part of the API and not marked as deprecated. There is not much API documentation about Document.ActiveView and UIDocument.ActiveView though. Are there any differences?
Rail Community
