cannot start Revit 2015 for API debugging
I have been working with Revit API for several versions but now I am having difficulties to debug with Revit 2015 API.
The plugin I created seems to work fine with Revit 2015. But when I try to debug it in VS by pressing F5, I saw Revit starts and immediately exits. The VS Output window shows a 0xe06d7363 Microsoft C++ Exception.
I googled this error but it seems to be very general and nothing relevant to this context.
I am using VS2013 on Windows 7. Any ideas is appreciated. Thanks!
You need to switch Visual Studio back to the legacy debugger. I think Jeremy covered this on his blog a while back.
The setting you are after is called "Use Managed Compatibility Mode" and is found in the Tools -> Options -> Debugging menu of visual studio.
You are absolutely right! Now it works as expected.
Since your mention it, I now remember Jeremy's blog regarding this setting, and put the link here just in case anyone is interested: http://thebuildingcoder.typepad.com/blog/2013/11/debugging-revit-2014-api-with-visual-studio-2013.ht...
But it didn't refer the symptom I was seeing.
Anyway, many thanks!
thank you for solving my long unsolved issue
