Hi
I want to get the list of all my phases but I don't know how to..
I've tried to do what they explain here : http://revitapisearch.com/
But it doesn't work..
That's my code :
And that's the error message in Revit when I run my app:
Any ideas plz?
Thank!!
Solved by peterjegan. Go to Solution.
Your app is running the "NotImplementedException" and ignoring your "void Getinfo_Phase"
Try:
public class Class1 : IExternalCommand { public Autodesk.Revit.UI.Result Execute( ExternalCommandData commandData, ref string message, ElementSet elements) { Document doc = commandData.Application.ActiveUIDocument.Document; PhaseArray....... ...your code.... .Show("Revit", prompt);
And get rid of the "NotImplementedException" block.
It doesn't work..
using System; using Autodesk.Revit.UI; using Autodesk.Revit.DB; using Autodesk.Revit.Attributes; namespace CreerVuesPourLePhasage { [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)] public class Class1 : IExternalCommand { public Autodesk.Revit.UI.Result Execute( ExternalCommandData commandData, ref string message, ElementSet elements) { Document doc = commandData.Application.ActiveUIDocument.Document; PhaseArray phase = doc.Phases; { String list = null; if (0 != phase.Size) { list = "Phases are"; foreach (Phase ii in phase) { list += "\n\t" + ii.Name; } } else { list = "No phases available"; } TaskDialog.Show("Revit", list); } } } }
It doesn't work because of the Execute()
and the error returns by visual studio is something like that (sorry for the translation I have visual studio in french..) :
'CreerVuesPourLePhasage.Class1.Execute(Autodesk.Revit.UI.ExternalCommandData, ref string, Autodesk.Revit.DB.ElementSet)' : all code paths don't return a value necessarily
