Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Can't get phases
9 REPLIES 9
Message 1 of 10
sabatierae
487 Views, 9 Replies
Can't get phases
Hi
I want to get the list of all my phases but I don't know how to..
I've tried to do what they explain here : http://revitapisearch.com/
But it doesn't work..
That's my code :
And that's the error message in Revit when I run my app:
Any ideas plz?
Thank!!
Tags (2)
9 REPLIES 9
Message 2 of 10
peterjegan
in reply to: sabatierae
Your app is running the "NotImplementedException" and ignoring your "void Getinfo_Phase"
Try:
public class Class1 : IExternalCommand
		public Autodesk.Revit.UI.Result Execute(
			ExternalCommandData commandData,
			ref string message,
			ElementSet elements)
Document doc = commandData.Application.ActiveUIDocument.Document;
PhaseArray.......
...your code....
.Show("Revit", prompt);
 And get rid of the "NotImplementedException" block.
Message 3 of 10
sabatierae
in reply to: peterjegan
It doesn't work..
using System;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.Attributes;
namespace CreerVuesPourLePhasage
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
            ref string message,
            PhaseArray phase = doc.Phases;
                String list = null;
                if (0 != phase.Size)
                    list = "Phases are";
                    foreach (Phase ii in phase)
                        list += "\n\t" + ii.Name;
                else
                    list = "No phases available";
                TaskDialog.Show("Revit", list);
 It doesn't work because of the Execute()
and the error returns by visual studio is something like that (sorry for the translation I have visual studio in french..) :
'CreerVuesPourLePhasage.Class1.Execute(Autodesk.Revit.UI.ExternalCommandData, ref string, Autodesk.Revit.DB.ElementSet)' : all code paths don't return a value necessarily
Message 4 of 10
peterjegan
Try: TaskDialog.Show("Revit", list); } return Result.Succeeded; } } }
Message 5 of 10
peterjegan
That was ugly. I hope this is better: TaskDialog.Show("Revit", list); } return Result.Succeeded; } } }
Message 6 of 10
peterjegan
} TaskDialog.Show("Revit", list); } return Resut.Succeeded; } } }
Message 7 of 10
peterjegan
Sorry, I can't get line feeds to work from here. See attached file
Message 8 of 10
peterjegan
Message 9 of 10
sabatierae
The attachment wasn't send to the server..
Message 10 of 10
sabatierae
Yeah It works!! thx!
Rail Community
