Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Can't find all instances of Revision notes in my project
4 REPLIES 4
479 Views, 4 Replies
Our Sheets use instances of "Manual_Revision" annotation symbols to document revision date, notes etc.
This code extract returns some, but not all, of these revisions.
Does anybody have any idea why I'm not picking them all up?
    Public Shared Function GetRevisions(doc As Document, frm As frmSheets) As String
        ' Creates a FamilyInstance filter for elements that are family instances of the given family symbol in the document
        ' Find all family symbols whose name is "Manual_Revision"
        Dim collector As New FilteredElementCollector(doc)
        collector = collector.OfClass(GetType(FamilySymbol))
        ' Get Element Id for family symbol which will be used to find family instances
        Dim query = From element In collector Where element.Name = "Manual_Revision"
        Dim famSyms As List(Of Element) = query.ToList() '(Of Element)()
        Dim symbolId As ElementId = famSyms(0).Id
        ' Create a FamilyInstance filter with the FamilySymbol Id
        Dim filter As New FamilyInstanceFilter(doc, symbolId)
        ' Apply the filter to the elements in the active document
        collector = New FilteredElementCollector(doc)
        Dim familyInstances As ICollection(Of Element) = collector.WherePasses(filter).ToElements()
        ' Prompt typical revision
        ParseRevisions(frm, familyInstances(0), True)
        For Each ele As Element In familyInstances
            ParseRevisions(frm, ele, False)
        Next
        Return "Found " & familyInstances.Count & " Revisions in Project"
    End Function
4 REPLIES 4
augusto.goncalves
The famSyms list alaways has only 1 element? Or do you have a .rtv with this? Which Revit version are you using?
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
in reply to: augusto.goncalves
My code finds 173 revision notes and I write them to a database but when I check them I can see that there are many missing.
I can provide the .rvt file if you would like to look at it. I'm an experienced AutoCAD and .net Programmer but I'm a total newbie to Revit and haven't really got my head round the object model and structure.
Steve
CZWG Architects
peterjegan
I agree with Augusto, it looks like you only do one type. I suggest
	foreach symbolId As ELementId in famSyms
	'Dim symbolId As ElementId = famSyms(0).Id
        Next
	Next
    End Function
in reply to: peterjegan
Thanks for the suggestion. I simplified my code and inserted a loop over my filtered list of famsyms with name "Manual_Revision" as shown.
    Public Shared Function GetRevisions(doc As Document) As String
	    Dim iRevisions As Integer = 0
	    'family instances of the given family symbol in the document
	    Dim faminsts As ICollection(Of Element)
	    'famsyms.count is 1 so the For each symbol loop is only passed once
	    Debug.Print("Found " & famSyms.Count & " family symbols where element.Name = 'Manual_Revision'")
	    For Each symbol As Element In famSyms
	        Dim filter As New FamilyInstanceFilter(doc, symbol.Id)
	        faminsts = collector.WherePasses(filter).ToElements()
	        For Each ele As Element In faminsts
	            'ParseRevisions(frm, ele, False)
	            iRevisions += 1
	        Next
	    Next
	    Return "Found " & iRevisions & " instances of FamilySymbol Manual_revision"
	End Function
This made no difference as there was only one match:
Found 1 family symbols where element.Name = 'Manual_Revision'
Found 173 instances of FamilySymbol Manual_revision
The 172 instances I found only included, for instance about 3 of the notes on this sheet snip. There was no revision with [Revision No] parameter value "C05" found in the entire project.
I'm missing something pretty obvious in my parsing of the Revit project!
Your assistance is appreciated!
Steve
CZWG Architects LLP
LONDON
Autodesk DevCon in Munich May 28-29th
Rail Community
