Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
cad block properties
2 REPLIES 2
Moustafa_K
579 Views, 2 Replies
Hi
is it possible to get Autocad Block properties in Revit API. such as Angle and Scale?
Moustafa Khalil
2 REPLIES 2
R.van.den.Bor
in reply to: Moustafa_K
Maybe this post helps you firther:
http://forums.autodesk.com/t5/revit-api/loop-cad-elements/m-p/4776117#M5460
Kind regards,
Remy van den Bor
ICN Solutions B.V.
Liked this post or found it usefull, don't forget the Kudo It won't hurt (at least not me).
Moustafa_K
in reply to: R.van.den.Bor
Thanks i will look into that and do some tests...
Moustafa Khalil
Autodesk DevCon in Munich May 28-29th
Rail Community
