Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
best solution to generate thumbnails of DWG, DXF and Revit files
1 REPLY 1
tkluysk
966 Views, 1 Reply
We're investigating ways of creating thumbnails of DWG, DXF and Revit files for use in a browser application:
- the user drops a Revit file on the window
- file uploads to server
- loaded by Revit (?)
- model & camera positioned
- snapshot taken/image saved
- image returned to browser
We know we can probably do it using Revit and the API.
The question is whether it can be done using cheaper tools:  Revit LT, or even other options.  As long as:
- those file formats are fully supported
- we can somehow pose the model and cameras (might also require getting model bounds)
We know Revit LT does not support 3rd party APIs, but maybe it can be controlled through a TCP port?
Any advice, insight and ideas welcome!
1 REPLY 1
gopinath.taget
in reply to: tkluysk
If thumbnail images are good enough than the following blog posts should help:
http://thebuildingcoder.typepad.com/blog/2009/06/rvt-and-rfa-thumbnail-image.html
http://thebuildingcoder.typepad.com/blog/2010/06/open-revit-ole-storage.html
Cheers
Gopinath
Rail Community
