Autoloader folder: ApplicationPlugins
Dale.Bartlett
Dale.Bartlett
Hi All,
It appears that the folders used for AutoCAD addins is also valid for use with Revit:
ie
C:\ProgramData\Autodesk\ApplicationPlugins\MySuperApp.bundle
instead of:
C:\ProgramData\Autodesk\Revit\Addins\2014\MySuperApp.bundle
Is this correct? I would much rather have a common installation folder for both applications (AutoCAD and Revit) managed via the XML manifest file.
Thanks, Dale
______________
Yes, I'm Satoshi.
augusto.goncalves
Yes, the ApplicationPlugins folder should work for both AutoCAD and Revit (on the current version)
Looking forward, we're moving the default to Program Files folder on AutoCAD environment.
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
jeremytammik
Dear Dale,
The Revit API help does not have anything to say on this subject, as you can see under Developers > Revit API Developers Guide > Introduction > Add-In Integration > Add-in Registration:
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-4FFDB03E-6936-417C-9772-8FC258A261F7
I asked my other colleagues, and they concur with Augusto saying:
Yes, that is the theory; Max, Maya and AutoCAD (at least) use C:\ProgramData\Autodesk\ApplicationPlugins.
As long the host app looks in that folder, it should work.
I’ve just checked and this location (C:\ProgramData\Autodesk\ApplicationPlugins\...) works for Inventor 2015 AddIns as well.
The Inventor API Help describes four recommended locations:
1. All Users, Version Independent
  • Windows 7 - %ALLUSERSPROFILE%\Autodesk\Inventor Addins\
  • Windows XP - %ALLUSERSPROFILE%\Application Data\Autodesk\Inventor Addins\
2. All Users, Version Dependent
  • Windows 7 - %ALLUSERSPROFILE%\Autodesk\Inventor 2013\Addins\
  • Windows XP - %ALLUSERSPROFILE%\Application Data\Autodesk\Inventor 2013\Addins\
3. Per User, Version Dependent
  • Both Window 7 and XP - %APPDATA%\Autodesk\Inventor 2013\Addins\
4. Per User, Version Independent
  • Both Window 7 and XP - %APPDATA%\Autodesk\ApplicationPlugins
I hope this helps.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
mikako_harada
Hi Dale,
In addition to what Augusto and Jeremy said, some background info.
%AppData%\Autodesk\ApplicationPlugins  or
%ProgramData%\Autodesk\ApplicationPlugins
are added to support our Exchanges Store apps.  You can find more information, or xml files from the publisher page:
http://www.autodesk.com/developapps
or more specifically about Revit apps publishing, from here:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=20143032
If you scroll down the page, you see a a table with recordings and ppts.  You may want to take a look to find the xml tags.
This is a the location all the products Exchanges apps goes. You will need to make sure you provide additional information in xml file and structure your apps as self contained as described in the publihser page.
I hope this clarifies.
Mikako Harada
rochajulissa73
Community Visitor
Community Visitor
soi
