I am trying to add a custom tab with links to our pdf tutorials. I can add the pushbuttons but i'm not sure how to add the command to open the desired file.
I am trying to use the following but not exactly sure where this needs to go:
System.Diagnostics.Process.Start("C:/test/test.pdf");
Just starting programming and need help!
Solved by tdaniel. Go to Solution.
