Hi
I have written an addin which needs to access the "Project Browser" element. It finds this element by iterating through a FilteredElementCollector. This approach works fine on Revit Englsih. However it appers that Revit French uses a different internal name for the "Project Browser". How can I access the project browser elements on non-English versions of Revit pls?
Paul
Solved by Joe.Ye. Go to Solution.
HI Paul,
In the non-English version, you can get the name string from the target Revit product. (Install that, and get the project browser window name.)
Not sure what's the usage after you get the "Project Browser" element?
There is no built-in name for the project browser window.
One way to get the project browser dockable pane is to get the DockablePaneId from DockablePanes.BuiltInDockablePanes.ProjectBrowser property.
And then get the project browser pane by:
DockablePane projectBrowser = new DockablePane(DockablePaneId);
