Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
access Appearance properties of materials
4 REPLIES 4
853 Views, 4 Replies
My purpose is to access the all material properties, in all tab (e.g., graphic, appearance, thermal, physics)
From the material class, to access appearance properites, I use the following code:
Document doc = m_material.Document;
AppearanceAssetElement aae = doc.GetElement(m_material.AppearanceAssetId) as AppearanceAssetElement;
However, how can I get the appearance properties, the AppearanceAssetElement does not have properties for such as "tint" "cutout"
How can I get accesss all the properties of materials through API?
4 REPLIES 4
jeremy.herbert
I'm also having this problem, I'm trying to access the keywords for different appearances but am having no luck. Can anyone help?
spesci
I would like to get the image path. Has anyone able to get this asset parameter?
jakob.noggler
Hi!
I know this is an older question, but maybe you still need help, or anyone else thats stumbles across this question.
This link should give you the information you need:
http://adndevblog.typepad.com/aec/2015/03/revitapi-how-to-get-asset-properties-of-material-i-want.ht...
Greetings
spesci
in reply to: jakob.noggler
Thanks for the info.
Autodesk DevCon in Munich May 28-29th
Rail Community
