Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Use a form in Revit API
5 REPLIES 5
sylvain14d
4780 Views, 5 Replies
I'm new in Revit API and i recently realese some simple API.
I'm now trying to do an API  which use a forms to ask some parameters value to the user in order to set this parameter value to the selected objects. I created the forms with visual studio.
I'm already not able to open the form...
This is my part of code called by pressing the button in revit ribbon panel :
Public Class CommandHTPOT
    Implements IExternalCommand
    Public Function Execute(
      ByVal commandData As ExternalCommandData,
      ByRef message As String,
      ByVal elements As ElementSet) _
    As Result Implements IExternalCommand.Execute
        Dim uiapp As UIApplication = commandData.Application
        Dim app As Application = uiapp.Application
        Dim windowsform As New Form1()
        Dim result = windowsform.ShowDialog()
    End Function
End Class
My research has so far not helped me... When i execute that code I have a transaction error (French language so can't tell you exactly the terms).
 Hoping some help !
Thanks a lots
5 REPLIES 5
jeremytammik
in reply to: sylvain14d
Dear Justin,
First of all, as a beginner, I strongly recommend that you take a close look at the Revit API getting started material, especially the DevTV and My First Revit Plugin tutorials.
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
That will already answer your question.
You can also look at the Revit SDK samples. Several of them display forms as well.
Good luck and have fun!
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
sylvain14d
in reply to: jeremytammik
Hi Jeremy,
Thanks a lot for this good tip ! I already use Revit SDK Sample. I just found information about Taskdialogue... But nothing about a windows form wich would have created with visual studio allowing to get back some informations.
I think that it's not so really complex. Maybe i have an error with this :
<Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Automatic)>
I do not really know how to go further
Really hoping some help
Best regards,
Sylvain
jeremytammik
Dear Justin,
Yes, the automatic transaction mode is deprecated and has been so for a long time:
http://thebuildingcoder.typepad.com/blog/2012/12/extra-transaction-or-regeneration-required.html
"automatic transaction mode is unofficially deprecated, and manual mode is recommended for all cases nowadays. Automatic transaction mode is considered obsolete."
http://thebuildingcoder.typepad.com/blog/2012/05/read-only-and-automatic-transaction-modes.html
Your add-in is probably not properly set up.
The getting started material will show you how to do so.
So will the Revit SDK samples.
There is absolutely nothing special you need to do to run display a Windows form.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
sylvain14d
Thank you Jeremy,
In fact it was not a Revit API programation problem but a classic vb.net problem.
I just use this and it works great.
Dim wf As New Form1
wf.ShowDialog()
Thanks a lot !
patrick.emin
Bonjour, pour votre information, nous avons un forum en français: https://forums.autodesk.com/t5/revit-et-bim-francais/bd-p/198
Patrick Emin animateur de la communauté francophone
Vous avez trouvé un message utile? Alors donnez un "J'aime" à ce message!
Votre question a eu une réponse satisfaisante? Voulez vous avoir l'amabilité de cliquer sur le bouton
 APPROUVER LA SOLUTION  en bas de la réponse qui apporte une solution?
Signez notre Livre d'Or
Rail Community
