Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Revit API Forum
Post 1 of 16
Revit Command Line Switches
2027 Views, 15 Replies
04-12-2006 09:55 AM
Are there any command line switches available in Revit? I've looked in the
help file, but found nothing. I'm looking for switches that tell Revit what
.rvt file to open with, and a switch to specify an External Tool to launch
upon startup. I would also be curious to know of any others that are
available.
Post 2 of 16
Re: Revit Command Line Switches
04-13-2006 11:02 AM in reply to: *Dave Blackburn
I guess I don't need to worry about the .rvt file switch, since no switch is
required in that case (just placing the full drawing path in the command
line does the trick). However, I am still curious about any actual startup
switches for Revit. Most importantly though, I'm wondering if anyone knows
of a way to tell Revit to issue a particular External Tool upon startup.
Are we stuck having to try and hook Revit and send the appropriate Windows
messages to accomplish launching an External Tool?
05-06-2015 12:43 PM in reply to: *Dave Blackburn
Bringing this thread back to life, any answers to the original question?
Post 4 of 16
05-06-2015 03:50 PM in reply to: miguelvalencia5598
As David says, no switch required to load the RVT model. Just list it on the command line with Revit.exe and Revit will open it.
Similarly for add-ins: no switch required. Revit will load them as specified in the add-in manifests located in the add-ins folder in the standard manner.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Post 5 of 16
05-31-2015 08:04 AM in reply to: jeremytammik
How can you open a file in a particular version with process.start?  I've tried many variations of the path to the .exe and the path to the file and always get an error message.  (File opens fine through UI.)  Thanks.
Post 6 of 16
06-23-2015 04:32 AM in reply to: jeremytammik
Replying on Command Line switches,
are there StartUp switches using Revit?
Is there a way to start revit (from API or add switch to .exe) using a specific .rte?
For now you can select a template after starting Revit, I would like to do it before I start Revit.
Thanks!!!
Rolph
Post 7 of 16
06-23-2015 04:42 AM in reply to: r.baggen
Dear Rolph,
I am not aware of any such switch.
You could probably write an add-in that creates a new project document based on any given template automatically at start-up, though.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Post 8 of 16
06-23-2015 05:37 AM in reply to: jeremytammik
In my case I wanted to start Revit with a particular file before it was opened.  I used the Idling event that looks for a txt file with a path in it.  As soon as Revit is finished loading, the idling event kicks in and finds the txt file and processes it with the API commands.
Post 9 of 16
06-23-2015 08:54 AM in reply to: michael_coffey
Michael,
using the Idling event is a possible approach, but not one I recommend. For this kind of a problem (start Revit with a particular file via the API), I suggest using the ApplicationInitialized event instead.It is raised by Revit only once after the application is initialize and after add-ins were started too. In the handler of the event you can use the OpenAndActivateDocument - it would work as long as there is no active document open yet, which can be easily tested, though.
Arnošt Löbel
Post 10 of 16
06-23-2015 09:13 AM in reply to: arnostlobel
Hi Arnošt,
Thank you for the good advice!
Look at these in-depth discussion of this all-to-unknown event:
http://thebuildingcoder.typepad.com/blog/2015/03/opening-and-activating-document-in-an-event-handler...
http://thebuildingcoder.typepad.com/blog/2015/03/automatically-open-a-project-on-startup.html
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
07-21-2016 09:16 AM in reply to: r.baggen
I could use a switch to set the default View Option.  For instance, one Desktop launch shortcut set to Mechanical, another set to Plumbing.
Post 12 of 16
07-21-2016 12:38 PM in reply to: theDarknessRules
Cool  idea.
Please submit it to the Revit idea station:
http://thebuildingcoder.typepad.com/blog/2016/05/idea-station-and-textnote-bounding-box.html#2
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Post 13 of 16
01-04-2017 04:30 AM in reply to: jeremytammik
Jeremy,
I am looking for Revit switch that would enable autpmatic load of Revit file as a local (silent mode). Reason- I need to get Dynamo Automation working on Central files ( I have about 80 files to process every iteration)
I explained my line of investigation here:
https://forum.dynamobim.com/t/dynamo-automation-for-central-files/8597?u=erlich.denis
Please, advise if it is possible to "decentralize" revit file via python script
Thank you in advance!
Post 14 of 16
01-04-2017 06:24 AM in reply to: erlich.denis
Dear Denis,
Happy New Year to you!
You have no need for any additional switch to auto-load a document on Revit start-up.
Just providing the full document path is sufficient, e.g.:
C:\>"C:\Program Files\Autodesk\Revit 2017\Revit.exe" Y:\a\rvt\Test.rvt
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Highlighted
Post 15 of 16
01-04-2017 06:47 AM in reply to: erlich.denis
I know this is not in answer to the last question, but it may be useful to others higher up the conversation.
These are the switches etc I'm aware of (tested in Revit 2017):
*no switch* <fully qualified path of file to open> (Opens a Revit file. Seems to work with a template or project file. Haven't tried a family. I've been doing this since Revit 2011, though I put /o in there so I know what it is, though that seems to be ignored.)
*no switch* <fully qualified path of journal file> (Replays a journal file.)
/language <language code such as ENU>
/viewer (Launch Revit in viewer mode.)
Cheers,
-Matt
Post 16 of 16
01-09-2017 04:23 AM in reply to: matthew.taylor
Dear Matt,
thank you for the succinct summary!
I promoted it to a blog post for better legibility and future reference:
http://thebuildingcoder.typepad.com/blog/2017/01/distances-switches-kiss-ing-and-a-dino.html#3
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
