Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Revit 2016 unable to retrieve grid.Curve
2 REPLIES 2
333 Views, 2 Replies
I'm trying to retrieve the curve property of a grid object in my Revit 2016 document, but somehow it's not working. When I debug my code VS tells me grid.Curve is null. But I can't figure out why.
I've based my code on this example: https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/Revit-API/files/GUID-...
foreach (Grid gridinstance in xxGrids)
     if (gridinstance.IsCurved)
          Arc arc = gridinstance.Curve as Arc;
     else
          Line line = gridinstance.Curve as Line;
xxGrids in this case is a list of Grid objects and is populated with some orthogonal grid objects. The IsCurved property of all of them is false, so I should be able to retrieve a line object based on the grid.Curve property but this is always null.
When I use the snoop current selection tool I can see that the curve property is an actual line with endpoint coordinates and more. Why can't I retrieve this via code?
Anybody any thought on this?
Thanks in advance..
Tags (2)
2 REPLIES 2
After some additional testing I've narrowed the problem down to the actual creation of the grid elements, in my case the grid elements are created in my code with a method which basically accepts 2 lists of XYZ's which represent the start and endpoints of the grid element:
public static void CreateGridElements(Document document, List<XYZ> startPoints, List<XYZ> endPoints)
     if (startPoints.Count == endPoints.Count)
for (int i = 0; i < startPoints.Count; i++)
Line line = Line.CreateBound(startPoints[i], endPoints[i]);
Grid grid = Grid.Create(document, line);
Whenever I've created a gridelement with this method, I'm unable to retrieve the Curve property of the grid element. When I created a grid element via the normal Revit UI it does work. Is there somehow a difference between grid elements which are created through API or UI?
arpankumar.macwan
Any update on this topic? I have same issue.
Rail Community
