Remove family type parameter
Hello. I know, that Revit Api allows me to create custom parameters in .rfa files and set their values. For example:
foreach (var type in neededFamTypes)
    familyManager.CurrentType = type;
    familyManager.Set(myStringParameter, "myValue");
Of course if I call type.HasValue(myStringParameter)  it will return true. But how can I delete paramter from type (not from whole family)? Something like  familyManager.Unset(myStringParameter) , and type.HasValue(myStringParameter) should return false then?
jeremytammik
I am not sure that you can add a parameter to only one type and not have it appear on others as well.
Can you?
To remove a family a parameter, I only see the FamilyManager.RemoveParameter method, which removes an existing family parameter from the entire family.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Thank you Jeremy.
mandy.changA2ADQ
Community Visitor
Community Visitor
Remove family type parameter where can i get it? (at Dynamo)
