Macro - open document as detach from central and save the document.
Message 1 of 29
Hello there,
I have come up with an idea of a Macro and would like to know whether it could be done and how could it be done. I have been working in a project and need to detach it from central for all the partners involved in the project, it is kind of an arduous task.
Therefore, I have thought on developing a macro with macro manager where i could open the active document as detach from central and they save it into a file.
Is this possible?
Many thanks!
Replies (28)
Message 2 of 29
I don't know if you can instantly detach the current local file.
But honestly you dont want to do that. worksharing enviroment is sometimes quite delicate and if you start detatching local files you might be sending the wrong files. .
I would create it as:
1. Sync to central & close the document
2. Open the central, detach and discard all the worksets
something like this should workish...
                    ModelPath MyCentralFile = doc.GetWorksharingCentralModelPath();
                    OpenOptions openoptions = new OpenOptions();
                    OpenOptions.DetachFromCentralOption = DetachFromCentralOption.DetachAndDiscardWorksets;
                    app.OpenAndActivateDocument(MyCentralFile, openoptions, false);
3. Save as a new file in folder x
4. Purge the drawing from all you dont need, save again
5. Done ?
Good luck!
Message 3 of 29
We actually are going through a few network pathing changes. (IT side) That are causing our files to have to be detached ->preserved ->resaved (same name) and relinquished all worksets. Do you think your script could be adapted to do this thorughout a directory?
Message 4 of 29
MehtaRajesh
Hi
Some kind of below script can Help you
m_app = commandData.Application;
app = m_app.Application;
// Check worksharing mode of each document
// Open Revit projects
OpenFileDialog theDialogRevit = new OpenFileDialog();
theDialogRevit.Title = "Select Revit Project Files";
theDialogRevit.Filter = "RVT files|*.rvt";
theDialogRevit.FilterIndex = 1;
theDialogRevit.InitialDirectory = @"D:\";
theDialogRevit.Multiselect = true;
if (theDialogRevit.ShowDialog() == DialogResult.OK)
 string mpath = "";
        string mpathOnlyFilename = "";
        FolderBrowserDialog folderBrowserDialog1 = new FolderBrowserDialog();
        folderBrowserDialog1.Description = "Select Folder Where Revit Projects to be Saved in Local";
        folderBrowserDialog1.RootFolder = Environment.SpecialFolder.MyComputer;
        if (folderBrowserDialog1.ShowDialog() == DialogResult.OK
         mpath = folderBrowserDialog1.SelectedPath;
                foreach (String projectPath in theDialogRevit.FileNames)
                 FileInfo filePath = new FileInfo(projectPath);
                        ModelPath mp = ModelPathUtils.ConvertUserVisiblePathToModelPath(filePath.FullName);
                        OpenOptions opt = new OpenOptions();
                        opt.DetachFromCentralOption = DetachFromCentralOption.DetachAndDiscardWorksets;
                        mpathOnlyFilename = filePath.Name;
                        Document openedDoc = app.OpenDocumentFile(mp, opt);
                        SaveAsOptions options = new SaveAsOptions();
                        options.OverwriteExistingFile = true;
                        ModelPath modelPathout = ModelPathUtils.ConvertUserVisiblePathToModelPath(mpath + "\\" + mpathOnlyFilename);
                        openedDoc.SaveAs(modelPathout, options);
                        openedDoc.Close(false);
Message 5 of 29
This wasn't written in c# was it?
Message 6 of 29
helengorina7713
Thanks for sharing the code.
there is a  minor typo in the second IF statement: Your code is missing the closing parenthesis - see in red
        if (folderBrowserDialog1.ShowDialog() == DialogResult.OK)
Message 7 of 29
MehtaRajesh
This code is written in C#.
Thanks and Regards,
Message 8 of 29
erlich_denis
Observer
Observer
Hi!
I am trying to recreate the macro in Revit using your posted code, but have a problem with the m_app.Application as it is not defined.
for a record, there were System.IO ans System.Windows.Forms classes that were not defined in the Revit 2015 Macro SHrpDevelop.
Please, advise what is missing.
Thank you!
 * Created by SharpDevelop.
 * User: user
 * Date: 1/9/2017
 * Time: 4:43 PM
 * To change this template use Tools | Options | Coding | Edit Standard Headers.
using System;
using System.IO;
using System.Windows.Forms;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
using System.Collections.Generic;
using System.Linq;
namespace test222
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    [Autodesk.Revit.DB.Macros.AddInId("XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX")]
    public partial class ThisDocument
        private void Module_Startup(object sender, EventArgs e)
        private void Module_Shutdown(object sender, EventArgs e)
        public void exampleagain(){
            ThisDocument.a
            m_app = Document.Application;
 string mpath = "";
        #region Revit Macros generated code
        private void InternalStartup()
            this.Startup += new System.EventHandler(Module_Startup);
            this.Shutdown += new System.EventHandler(Module_Shutdown);
        #endregion
Message 9 of 29
MehtaRajesh
Add
Autodesk.Revit.UI.UIApplication m_app;
Before
Check for following using and respected references
using System;
using System.Linq;
using System.Text;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit;
using System.IO;
Rajesh
Message 10 of 29
erlich_denis
Observer
Observer
Thank you!
Someone actually suggested to do this:
Replacing these 2 lines
By this
Autodesk.Revit.ApplicationServices.Application app =this.Application;
And it worked as well.
Now the struggle is to silent all interruption/ such as missing links, double geometry etc. , that usual answere i " yes" and " ok" but i have to be physically present, so on a batch process of 68 central models it becomes a problem
With Regards,
Denis Erlich
BIM Manager Design-Build
Crosslinx Transit Solutions - Constructors
Tel.: 416-252-5315 Ext. 52258416-252-5315>
Mobile: 416-529-9856
4711 Yonge Street,
Toronto | Ontario | Canada | M2N 6K8416-252-5315>
Message 11 of 29
helengorina7713
here is the full solution- with some dialog for the user:
you need to add system references for the user dialog to work.
works in 2016, did not test in 2017
 * User: gorina_admin
 * Date: 9/30/2016
 * Time: 2:09 PM
using System;
using System.Linq;
using System.IO;
namespace batch
    [Autodesk.Revit.DB.Macros.AddInId("30EBC375-5A4C-4917-AB07-D7212C9ED3FA")]
    public partial class ThisApplication
        #endregion
        public void savenotworkshared()
theDialogRevit.InitialDirectory = @"C:\";
 string mpath = "";
                        Document openedDoc = Application.OpenDocumentFile(mp, opt);
Helen Gorina
Perkins+Will
Message 12 of 29
dnenov
Thanks so much for that! So useful 🙂
Message 13 of 29
sabeel.shaik
hey, can I get the final working macro for 2017. it will be very helpful.
thanks.
Message 14 of 29
helengorina7713
Have you tried it in 2017?
It should work in any version
Message 15 of 29
sabeel.shaik
its not working.
Message 16 of 29
helengorina7713
It works for me
Please send the file you are using it on
I will try to look at it next week
Message 17 of 29
sabeel.shaik
can u send me a private message. I will share details.
Message 18 of 29
helengorina7713
intercepting Revit messages is a herculean task where you need to know exactly what you are hunting for. Not feasible in a simple macro.  My targeted use was for multiple linked room models in a gigantic hospital. Those were typical rooms with beds and other equipment, and the team for some reason used worksharing even though for each room type there was just one planner. When you have huge amount of linked workshared file, Revit performance takes a hit. After making them not workshared, performance improved significantly
Message 19 of 29
helengorina7713
I have tested in 2019- everything is working fine.
do not forget about references - you need to configure them on your system
and do not forget to re-build the solution on your machine
you need editing permissions to the folder where Revit stores Macros. Usually it is C:\ProgramData\Autodesk\Revit\Macros
Here is full code, and it works in any version of Revit from 2016 to 2019.1
 * Date: 9/30/2016
 * Time: 2:09 PM
 * rebuilt without errors for 2019.1 on 8/15/2018
using System;
using System.Linq;
using System.IO;
namespace batch
		#endregion
				string mpath = "";
Message 20 of 29
plamen.hristov
Hey Gorina,
I am new to Macros in Revit and I am trying your macro. Can you elaborate a little bit more on how to configure references or direct me to a source explaining those?
Thank you so much for your help!
