How to create an in-place mass
Hi there,
Does anybody know if and how one can make an in-place mass with the revit api. All examples I can find is the mass is created as seperate .rfa family and I don't want that. I need an in-place family of type mass.
So, I know doc.Create.NewExtrusionForm works in an familydocument, but I am searching for it's equivalent in project document.
jeremytammik
Dear Remy,
Creating an in-place mass is not supported by the Revit API.
That is why people create families in the background instead, and insert an instance of them:
http://thebuildingcoder.typepad.com/blog/2011/06/creating-and-inserting-an-extrusion-family.html
And that, again, is why the DirectShape element was introduced in Revit 2015 -- it allows you to create faceted geometry directly in the project without the need for an extra background family definition:
http://thebuildingcoder.typepad.com/blog/2014/05/directshape-performance-and-minimum-size.html
http://thebuildingcoder.typepad.com/blog/2014/11/directshape-versus-families-category-and-texture.ht...
https://github.com/jeremytammik/DirectObjLoader
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Thanx Jeremy, actually I already thought this wasn't possible but sometimes you hope your wrong 🙂 I will give directshape a try.
jeremytammik
Dear Remy,
I thought you would know that.
And yes, while there is life, there is hope!
So it is always worthwhile asking... again and again...  🙂
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
m.buehler1
I am keeping asking for an in-place mass API - Specially after we worked with Autodesk consultant service on a workflow which places adaptive families (curtain wall panels) to points/lines in-place mass.
The workflow defined by Autodesk turned out soon as impossible without API - Now we define the model elsewhere, store to a database the workpoints and create them inside Revit by DirectShape. Plus adding commands to update..
But we keep asking..
jeremytammik
Dear Michael,
Have you voted for API access to the in-place mass in the Revit Idea Station?
That is the main driving force for implementation of developer requests nowadays.
Do you have a number for a wish list item? I am pretty sure one exists.
I would name both the wish list item number and the link to the Revit Idea Station entry in a post like yours.
Furthermore, have you looked into using a direct shape element instead of an in-place mass?
https://thebuildingcoder.typepad.com/blog/about-the-author.html#5.50
It is a much more modern element with better API support.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
m.buehler1
Hi Jeremy
Yes I voted for the 'Revit API on in-place mass'; I found this one:
https://forums.autodesk.com/t5/revit-api-forum/how-to-create-an-in-place-mass/m-p/8393398
And yes: Currently we are working on a DirectShapes based implementation. However, the use of DirectShapes requires custom commands to create/modify which is not ideal. In our case reference lines to drive manufacturing data (similar as shown in AU 2018 Las Vegas presentation 'The Future of Workflow Forge Automation'..  I will send a more detailed feedback to those guys directly)
