In Dynamo in the provision of "Revit Background Preview" to the run of the results,
You can preview in Revit.
How does the Revit API work?
Thank you very much!
Solved by Charles.Stokes. Go to Solution.
All that Dynamo does when you turn on that option is generate a preview in it's own engine. I don't believe it has anything connected to the Revit API.
