Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Revit API Forum
Highlighted
Post 1 of 8
Distance between two points (XYZ) along a given vector
141 Views, 7 Replies
12-13-2016 04:06 PM
Simple question, does the Revit API have a method of returning the distance between two points along a given vector?
I realize there are ways to manually do this, but I was wondering if the Revit API had something natively to make my code a little cleaner.
Thanks!
If you need the distance of the points projected onto the given vector:
XYZ p1 = new XYZ(0, 10, 0);
XYZ p2 = new XYZ(10, 60, 0);
XYZ direction = new XYZ(30, 60, 0);
double distance = direction.Normalize().DotProduct(p1.Subtract(p2));
// double distance = Math.Abs( direction.Normalize().DotProduct(p1.Subtract(p2)));
Dear Everybody,
I would award the main prize and cigar to Fair59.
Partly for providing what I guess might be the right answer.
Above all for guessing what may or may not be the right intended question.
Dear @mhillis, you might want to hone your question asking skills a bit.
Is this an accurate description of your needs?
Question: Given points p1 and p2, what is the distance between them, measured along the line L?
If that is indeed what you need, you are actually not asking about the distance between the points at all.
These two points, together with the direction w of L, define two planes.
You are asking about the distance between those two planes.
Are you?
If so, Fair's answer is absolutely accurate and can be reformulated as:
Answer:
 v = p2 - p1
w = L.direction.normalise
distance_along_w = v.dotProduct( w )
Unfortunately, the Revit geometry API is not full-fledged and therefore lacks a method to return the distance between two planes.
Otherwise, that would probably provide an even more straightforward path.
The suggested one is very direct and efficient, though, and hard to beat in those respects.
I hope this helps and that we collectively succeeded at nailing your intention.
Best regards,
Jeremy
Re: Distance between two points (XYZ) along a given vector
12-13-2016 04:44 PM in reply to: mhillis
You can use a Autodesk.Revit.DB.Line
There is a double Length property that it inherits from Curve.
Post 3 of 8
12-14-2016 01:36 AM in reply to: mhillis
Hi @mhillis
Where pointA and pointB are XYZ points:
dim distance as double = pointA.DistanceTo(pointB)
The XYZ class also has .multiply and .divide functions if you want to go a proportion of that distance along a vector.
Cheers,
-Matt
12-14-2016 02:55 AM in reply to: matthew.taylor
Shame on me, Mr. Taylor, shame on me for missing that!
Post 5 of 8
12-14-2016 03:30 AM in reply to: GonçaloFeio1321
Haha. I did a similar thing just yesterday, so don't feel bad! Smiley Very Happy
Post 6 of 8
12-14-2016 04:17 AM in reply to: mhillis
Post 7 of 8
12-14-2016 10:36 AM in reply to: mhillis
Dear Everybody,
Are you?
Answer:
  v = p2 - p1
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Post 8 of 8
01-09-2017 04:26 AM in reply to: jeremytammik
I promoted this thread to a blog post for better legibility and future reference:
http://thebuildingcoder.typepad.com/blog/2017/01/distances-switches-kiss-ing-and-a-dino.html#2
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
