Create a view template
michele.verda
michele.verda
It's possible to create a view template?
I noticed that there is a property IsTemplate but is read-only.
A view templates is not tied to a level but if I try to use the NewViewPlan() method passing a null value as a level, Revit throw an exception.
jeremytammik
Dear Michele,
I am afraid this is currently not possible. At least I see an open wish list item in ur database for this functionality. I added a note of your wish to it.
Cheers, Jeremy.
Jeremy Tammik
Autodesk Developer Network -- http://www.autodesk.com/joinadn
The Building Coder -- http://thebuildingcoder.typepad.com
Jeremy Tammik
Developer Technical Services
The Building Coder
Dale.Bartlett
Has there been any development on Creating View Template in 2014/2015? Or is it possible to copy any existing View Template and then adjust properties to suit requirements? I have only just started looking so have not done a lot of research yet. Dale
______________
Yes, I'm Satoshi.
ABuschmann
Please note that this is very probably very unsupported - at least it feels very weird to me. But it works, so I thought I might as well share it:
public View duplicateTemplate(View template, string newName)
if (template == null || !template.IsTemplate) return null;
Document doc = template.Document; var newIds = ElementTransformUtils.CopyElement(doc, template.Id, XYZ.Zero); ElementId newId = newIds.FirstOrDefault(); View newTemplate = doc.GetElement(newId) as View; if (newTemplate != null) newTemplate.Name = newName; return newTemplate; }
I have tested this in Revit 2015 and 2016.
Duplicate a view: View.Duplicate
Duplicate a view that is a template: ElementTransformUtils.CopyElement(doc, id, XYZ.Zero)
