cannot retrieve omniclass number (Revit 2017).
My Code :
public RenderNodeAction OnElementBegin(ElementId elementId)
Element El = _StackDoc.Peek().GetElement(elementId);
BuiltInParameter _bipCode = BuiltInParameter.OMNICLASS_CODE;
BuiltInParameter _bipDesc = BuiltInParameter.OMNICLASS_DESCRIPTION;
String CatS = "Show Standard parameters in selected " + CTCT + ":\n";
foreach (Parameter para in El.Parameters)
string defName = para.Definition.Name + " = ";
// Use different method to get parameter data according to the storage type
switch (para.StorageType)
case StorageType.Double:
//covert the number into Metric
defName += para.AsValueString();
Double Test = para.AsDouble() * 25.4;
String TESTS = Test.ToString();
break;
case StorageType.ElementId:
//find out the name of the element
ElementId id = para.AsElementId();
if (id.IntegerValue >= 0)
defName += _StackDoc.Peek().GetElement(id).Name;
else
defName += id.IntegerValue.ToString();
break;
case StorageType.Integer:
if (ParameterType.YesNo == para.Definition.ParameterType)
if (para.AsInteger() == 0)
defName += "False";
else
defName += "True";
else
defName += para.AsInteger().ToString();
break;
case StorageType.String:
defName += para.AsString();
break;
default:
defName = "Unexposed parameter.";
break;
CatS = CatS + defName + "\n";
String OmiClass = "";
if (El.get_Parameter(_bipCode) != null)
OmiClass = "<" + El.get_Parameter(_bipCode).AsString() + ">";
else
OmiClass = "<>";
if (El.get_Parameter(_bipDesc) != null)
OmiClass = OmiClass + "<" + El.get_Parameter(_bipDesc).AsString() + ">";
else
OmiClass = OmiClass + "<>";
TaskDialog.Show("Debug", CatS + "\n\n OmiClass = " + OmiClass);
return RenderNodeAction.Proceed;
My Rvt Model and Result on Windowns (in attachment).
Philippe.
Solved by matthew_taylor. Go to Solution.
Hi @pmeigneux,
Have you used RevitLookup to check whether you are looking in the same place?
e.g. Not on an element, but on a familysymbol etc.
Everything will become clear.
Cheers,
-Matt
RevitLookup can be found here: https://github.com/jeremytammik/RevitLookup
It allows you to browse selected elements, the document database etc.
Once you have it installed, you would select the door > Revit Lookup > Snoop Current Selection > Family Symbol (in right-hand pane) > Parameter Set (in right-hand pane), OmniClass Number (in left-hand pane), the values will then be shown in the right-hand pane.
A lo-fi method using the actual Revit UI can be seen in the attached image.
RevitLookup is an indispensable tool for browsing Revit. Install it as a top priority.
Cheers,
-Matt
Thank you Matt.
How from the element having access to his family and the parameters of this one?
Philippe.
Hi @pmeigneux
Something like this:
dim famInstance as FamilyInstance =trycast (elem,familyinstance)
Dim famSymbol as familysymbol = famInstance.symbol
then get the parameter from the famSymbol object.
All of this will all become very apparent when you use RevitLookup. I cannot stress enough that you should install it and use it regularly to see the association between objects etc.
Cheers,
-Matt
