Remote General Discussion
New Member
frank.beier
Message 1 of 2 (184 Views)
When the connection is slow you have pop up in the middle of the screen
184 Views, 1 Replies
11-13-2013 03:17 AM
When the connection is slow, you get an information window in the middle of the screen.
This window shows the message " The Network You Are Using Is .....". This window will stay fore ever !!
Is there an function to close it? It overlap everything - you cant work! The speed is ok - but the message window is the biggest problem to work around it!
See attachment
Regards
Frank
New Member
autodesk.remote.dev
Message 2 of 2 (158 Views)
Re: When the connection is slow you have pop up in the middle of the screen
11-22-2013 03:42 PM in reply to: frank.beier
This message is designed to show only once per connection.  Remote has the ability to re-connect if the connection drops out and this may be causing the message to show more than once.   Do you notice Remote having a long lag before this message show up?
Post to the Community
New Post
Need installation help?
New Remote Category!
The Remote forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
