Remote General Discussion
Member
chrislee5427
Message 21 of 27 (238 Views)
Re: Welcome to Autodesk Remote
01-28-2014 04:01 PM in reply to: mirandatbone
I am also having the same problem as Tony. can't install autodesk remote on my laptop. it stops and disappear when I tried to install.
Can you help me with that , David Dembkoski?
Employee
schmiej
Message 22 of 27 (230 Views)
01-28-2014 04:04 PM in reply to: chrislee5427
This may be related to the installer not being able to install and run the Visual C++ 2010 Redistributable package. You can try to install it yourself then run Autodesk Remote’s installer.
Visual C++ 2010 Redistributable package Download location: http://www.microsoft.com/en-us/download/details.aspx?id=5555
Autodesk Remote requires 32-bit (x86) even on 64-bit OS’s.
Product Support
asburyj
Message 23 of 27 (228 Views)
01-28-2014 04:05 PM in reply to: chrislee5427
Could you provide some additional information?
·         What OS are you installing on?
·         Does this crash happen on all systems you install on, or only one?
·         Would you be willing to provide us the installer logs?
Attach the following files found at: %localappdata%\Temp (open file explorer and copy that exact line in, it will take you to the temp folder)
  - AdRemote_Installer_Log.txt
  - All files starting with osvc_
Jeffry Asbury
Member
chrislee5427
Message 24 of 27 (216 Views)
01-29-2014 08:57 AM in reply to: asburyj
MY OS: Windows 7 Professional w/ service pack 1.
Autodesk Remote installtaion does not work on this computer only.
See attached installtion log.
Member
chrislee5427
Message 25 of 27 (213 Views)
01-29-2014 09:06 AM in reply to: schmiej
Thanks! schmiej.
Your solution works.
Visitor
JAAKOBSOLLA4772
Message 26 of 27 (13 Views)
12-17-2014 12:00 AM in reply to: bradnee
Hi
We´re trying to install Autodesk Remote to one of our desktops and a laptop. Both installations stop at the point when "Cheking connctivity to download server on port 443" and later give "error code: -550" message.
Is there a work around for this problem? We have tried solutions posted on this discussion.
Thanks in advance
Tapani
Product Support
asburyj
Message 27 of 27 (5 Views)
12-17-2014 07:34 AM in reply to: JAAKOBSOLLA4772
Sounds like a firewall relates issue. If you have disabled your local firewall it may be a firewall or web proxy on your network blocking the connection. Have you worked with your It group to ensure that port is open?
Jeffry Asbury
Post to the Community
New Post
Need installation help?
New Remote Category!
The Remote forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
