I've just been informed that there is an update for Autodesk Remote.
Unfortunately i tried to run it but it wont work. Please see attachements.
FYI, I'm running Windows 7 64 Bit, SP 1
Solved by schmiej. Go to Solution.
Duncan,
In some cases, the auto-update may not properly rename the file on download and execution. If this occurs, you can either open up the directory the error message is displaying and run setup.exe or download the latest version from https://apps.exchange.autodesk.com/ACD/en/Detail/Index?id=appstore.exchange.autodesk.com:autodeskrem...
Thank you.
