I tried installing Autodesk Remote on my home computer. I receive the following message: "There was an error installing the Autodesk Remote service. Service install Error Code: -500. When I click OK, the setup window goes away and nothing happens. Any ideas? See attached image.
Running Windows 7 SP1
I would suggest the following.
Disable your Antivirus temperarily.
Ensure following ports are not explicitly blocked on your firewall between the local machine and the internet.
8090 - 8300 UDP Used for client to host communications,
7182 UDP
8080 - 8090 TCP (outgoing)
80, 443 TCP (outgoing) Used for HTTP and HTTPS communications
Ensure the following domains are not blocked for HTTPS:
*.otoy.com
*.webcl.com
*.otoyserver.com
Download a fresh copy of the installer and run it again with an admin account.
