Remote Forum (Read Only)
Welcome to Autodesk’s Remote Forums. Share your knowledge, ask questions, and explore popular Remote topics.
Cannot Sign In
4 REPLIES 4
jamal
628 Views, 4 Replies
Cannot Sign In
I downloaded the client and it installed just fine.  The remote comes up and asks me to sign in.  When I click the sign in button nothing happens.  It is not frozen, but nothing happens when I click sign in.  I restarted my computer, tried re-installing the client, but nothing seems to fix it.
Tags (1)
4 REPLIES 4
asburyj
in reply to: jamal
Hi Jamal,
This may be a firewall related issue.
The following ports must not be explicitly blocked on either the local machine or any intervening firewall between the local machine and the internet (for both host and client machines):
8090 - 8300 UDP Used for client to host communications,
7182 UDP
8080 - 8090 TCP (outgoing)
80, 443 TCP (outgoing) Used for HTTP and HTTPS communications
Ensure the following domains are not blocked for HTTPS:
*.otoy.com
*.webcl.com
*.otoyserver.com
In addition some antivirus softwares have been known to block the remote application so you may need to adjust your antivirus settings to ignore Autodesk remote
Jeffry Asbury
tylern
in reply to: asburyj
i am having the exact same issue,
ive given permission to Remote to go through my fire wall,
no antivirus interference.
The thing is,is that it worked before, (a couple weeks ago) but now when i click sign in, nothing comes up.... no log in box, nothing..
asburyj
in reply to: tylern
Has anything on your network changed? New network Hardware or ISP? New firewall on your system? You may also wish to also try upgrading to the 1.5 version of the client if you haven't yet.
Jeffry Asbury
schmiej
in reply to: jamal
The backend server does a time check on the token authorization while signing in. Check that your computer's date and time is set correctly.
As a 2nd check, go to accounts.autodesk.com and try signing in.
Thanks.
