What's the difference between ReCap and ReMake? I've been reading the intro pages, and it looks like ReCap works with point clouds, and ReCap Pro and ReMake work with meshes? Then, what's the difference between ReMake and ReCap Pro? The ReMake webpage says ReMake can clean up meshes from ReCap, so would it be better to start in ReMake and skip ReCap?
The other threads with this question were drone specific. I don't need GeoTiffs or to work offline at the moment, just need to know which is the best software to create 3D models from 2D images?
Bev
HIya.
let me try to position them:
- anything connected with data from Laser scans ( register, clean up and prepare for downlstream workflows - you need ReCap Pro) as part of the subscription you get also access to ReCap 360 which is the photo to 3d mesh solution mainly focused around drone capture and landscape type of use where ortho imagery etc is important.
ReCap also allows you to combine laser scan data of a building with photo scanned data from a drone - in a POINT cloud environment
and reCao ahas a service to convert a laser scan to mesh and then clean up fix and export in remake
if you are not interested in drone data, ReMake is for you - its a complete solution from capture to high end model prepped for further design use, AR?VR, 3d printing or publish on the web.
(the quality of the 3d models are same regardless if you send them from ReMake or from reCap360 - what ReMake offers is an environement that can create but also clean up fix edit and optimize the HUGE meshes that are a usual result when high quality meshes are made from reality and prepare them for the above mentioned use
hope this helps
tanja
ReCap and ReMake uses exact same service/engine under the hood.
Currently, ReCap has the ability to input survey points on the images which ReMake does not have. On the other hand ReMake has a comprehensive set of tools to process extremely large datasets (something that drones can easily generate).
Murali
Not sure if this will help, but I have spent the last few days trying to use ReMake. So far it has not produced anything remotely identifiable as the things I have tried to "remake". Having the survey points or anything that could help the computer understand when the image angle and camera position moves seems like it would be better. Maybe ReCap is better for this? I hope so because so far ReMake doesn't work at all and takes hours of work and produces useless meshes that look like nothing. I would suggest you try ReCap or maybe look for another solution personally
Hi Murali...are there any possibilities in combining ReCap/ReMake capabilities? What if some survey type images with large over/side-lap? James
Hi...what kind of heritage sites are you scanning? I'm working on the Chelsea Plantation in King William County VA and other sites in Williamsburg and Yorktown. When I figure how to share/include people on my site I'll share some stuff...Rgds., James
Hi @infinitetechs,
there are many users out there who were able to create amazing reconstruction by using ReMake. Could you please be more precise and write down more informations and technical details about your attempts? Also, it would be really useful to understand the issue you experienced, and hence helping you out, if you could share a screenshot of your datasets.
Thanks.
Cheers,
V.
We are evaluating the possibilities. Although we haven't been working on it, we will consider your question as a request/wish-list. Thank you!
Murali
Thanks for clarifying this but I noticed that ReMake models are much larger than ReCap models around 10 to 15 MB in file size actually.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
What i wish to do is to convert a 2D picture into 3D. What is better for this situation? Remake or Recap Pro?
All i want to do is use google earth pro to capture a video of sydeny opera house and then take some photo of that in 2d form, then use remake to convert that into a 3d mesh. Is that what recap is but newer then remake?
Hi @raghavsood999,
We would like to inform you that ReMake is moving to Autodesk® ReCap™ Photo, our new photo-to-3D service with the capacity to process up to 1,000 photos. ReCap Photo is available immediately through a subscription to ReCap Pro.
Features and benefits of ReCap Photo include:
To learn more about the benefits of ReCap Photo as well as to get access to a special promotional offer see this article.
For more info on ReMake and this change you may check this FAQ article.
