Hi Forum I have a situation where i would like overlay two meshes of a similar product but made by different manufacturers to see the geometric differences. I would like to know if auto desk has software to achieve this or if anyone knows of software that may do this. I currently use recap 360, remake, inventor and auto cad. I am seeing if there is a better solution than modeling another product then starting a different assembly in the inventor software if i dont have to. All opinions and help would be greatly appreciated
Solved by ValerioRizzo. Go to Solution.
Hi @andrew091267,
Remake Pro and Educational have both a tool for Difference Analysis. You can find it in the Action Menu > Analyze > Compare Two models.This tool analyzes the volumetric differences among two models in a given range of confidence and returns the result in form of a termal map. It is useful for tracking changes of captured object over time or comparision between as designed (CAD) and as made and than scanned objects. Also, you can define the range that is of your interest as well as the tolerance value.
I hope this helped.
Cheers,
V.
Hi ValerioRizzo Thank you for the reply i think you have solved the issue i will give it a try and see what results i get.
