This is more of a technical question for ADSK.
When using the Select by Plane tool, we can select a minimum of 3 points in order to define a plane.
But, does selecting more than 3 points increase the 'accuracy' by averaging the plane out across all points?
Solved by yan.fu. Go to Solution.
Yes. You are correct.
It will average the plane out across all picked points.
Yan
