ReCap / ReCap 360 / ReCap 360 Ultimate 2.1.1.2
ReCap [Direct Download]
ReCap 360 / Ultimate [Direct Download]
ReCap / ReCap 360 / ReCap 360 Ultimate 2.1.0.17
ReCap / ReCap 360 / ReCap 360 Ultimate 2.0.2.1 (July hotfix)
ReCap / ReCap 360 / ReCap 360 Ultimate 2.0.1.5 (May hotfix)
ReCap 2.0.0.255: [Direct Download]
(ReCap 360 Ultimate feature only)
ReCap 1.4.2.8 (January Hotfix): [Direct Download]
In some cases, survey alignment is re-applied when going back to registration mode
Fix issue where unified export can be incorrect for projects with large coordinate offsets
Fix issue with occasional point mismatch on unified export
ReCap 1.4.2.2 (November Hotfix): [Direct Download]
The Update Origin function could fail for some projects with large coordinate offsets
Small 'target' scans in multi-scan PTX files would be placed at 0,0,0, causing issues w/ project extents, etc
Group (and project) merge could fail and/or produce incorrect results when the incoming group's base transformation was non-trivial.
Occasional crash in indexing, resulting in a 'C++' Assert message.
Some legacy issues were causing reduced dynamic intensity range in structured data and incorrect ZFS intensity.
In some edge cases, registration can crash due to some cached information becoming invalid.
ReCap 1.4.1.7 (October Hotfix): [Direct Download]
Fix issue with incorrect point size after some navigation operations
Fix exception upon first launch with large-coordinate, unstructured data formats
Fix for ‘Clear Survey Data’ operation
Fix issue where the ‘survey’ status of a target could not be changed once set
Fix issue where, in some cases, registration results could be incorrect for new scans after reloading a project
Small changes to Registration reporting to disambiguate results between normal and target-enhanced modes
ReCap 1.4 (1.4.0.132) New Features:
(For more information on these new features, please refer to this guide: PDF)
ReCap 1.4 (1.4.0.132) Major Bug fixes:
ReCap 1.3.5.1 (June Hotfix):
ReCap 1.3.4.5 (Hotfix 1):
ReCap 1.3.4.5 (May Hotfix):
ReCap 1.3 (2015) New features/functionalities:
• Integrated Application Manager as software delivery solution which will keep user informed of important product updates, by sending alerts to your desktop.
• Provide more license options: Network license and usage based license.
• Improved Annotation functions: Allows user to edit existing measurement; Allows user to create annotation in Real View; Support title and body for note; Support hyperlink for note; Better look & feel for annotation; provide visual feedback during annotation placement.
• Capture Codec Kit.
• Allow user to quick view registration result.
• Improved display quality of gradient ramp, add support for user-defined label positions.
• Add function to clear all survey data from a project.
ReCap 1.3 (2015) Major Bug fixes:
• Display issue for Project with large coordinates.
• Scans will not index if original raw file is moved or removed.
• Publishing maps only to 360 causes 404 when loading 360 projects.
• Removed scan still displayed in project navigator under specified conditions.
• Unable to customize elevation values.
• Click mirror ball in 3d is not navigating to the nearest scan.
• Index failure caused by temp folder is not set/loaded properly when system is upgraded from K2/1.0.
• Add/Remove Registration Group is not auto-saved.
• Unit conversion error.
• Add folder of ZFS fails due to duplicates if ZFPRJ file exists.
• Selected scan's thumbnail cannot be highlighted after switching during registration.
• User can add notes/annotation to a point where there is no coordinate detected.
• LAS Import does not process intensity.
• Gradient ramp can have duplicated names.
• Export to unified rcs failed if the project contains cropping data.
• Random crash when clicking on mirror balls.
• Crash when opening a rcp file with many deletion selections.
• Crash when cancel during exporting to E57.
• Crash loading RCP with large number of region/selection.
• Crash when remove one folder from search path.
• Survey points cannot be enabled or disabled unless scan is loaded.
• User cannot navigate to the corresponding scan after deleting and adding scans in a project.
• ReCap doesn't colorize raw scans saved in SCENE.
• Open legacy rcp in ReCap 1.2, it's shown in Height display mode by default.
• For some scans RCS exported has no intensity.
• Some pcg can't be imported.
• Alignment Review Orientation always centers about 0,0.
• Memory Leaks in Registration with certain data sets.
• 2.5d shows the real view of previous scan sometimes.
• Survey Alignment Change doesn’t create/update Survey Report.
ReCap 1.2 New features/functionalities:
• Integrate Autodesk Meta license and provide 30 days trial.
• DeCap: Major functionality of ReCap Pro via a command-line interface. Internal and external partners will be able to leverage ReCap Pro functionality through a simple, high-level interface without needing to use the native user interface.
• Users can queue up registration results, allowing them to make progress on the next scan while the scan refinement runs in the background.
• Final registration view update.
• Allows the user to return to the registration environment to review/edit/add survey points or remove scans from the project.
• Expose new preferences for ReCap projects that will allow Users to specify unit type, decimal precision; Modify how coordinate prefixes appear in the program (XYZ); Designate automatic simplification if a unit value is too big or too small for the specified unit (i.e. display 1000mm as 1 m)
• Expose a small coordinate display in the bottom left corner of the ReCap window.
• User interface improvements.
• Drag and drop files from Windows Explorer to ReCap to process.
• Support Faro 5.2 scan version.
ReCap 1.2 Major Bug fixes:
• Cancel creating project is slow.
• Fix crash during export when indexing is in progress.
• Fix Crash when switching to real view after skip registration when some scans are still indexing
• Indexing conflict with publishing to 360.
• Cannot return to 3D view after clicking "home" button during indexing
• Auto setting with Max Memory setting.
• Exporting failure of unstructured data when set unify spacing as 0mm.
• Reopen a suspended project doesn’t enter import workflow.
• Recap freezes when survey points are created near border and survey UI is off screen.
• Indexing Freeze if Temp Files don't exist.
• Region will disappear after dragging mouse from blank area to cover it in Project Navigator.
• Text label on gradient ramp is cut off when range is too large
• Fail to publish sometimes.
• Fail to publish files if project name contains special characters.
• Crash to suspend import during registration.
• Crash when remove scan from add file view during register queuing.
• Publishing fails with large number of scans.
• Performance issue when combining multiple projects.
• Indexing large PTX file never completes.
• Recent Projects shouldn't appear when it’s removed.
• For some scan types (PTX specifically) the RGB and Intensity are not correctly set during index.
• Duplicate system gradients when edited.
• Crash during rcc generation for special ptx files.
ReCap 1.1 Hot fix:
• Crash while trying to align two rcp files
• Scanorama is not refreshed when clicking other mirror ball or scan location once user has clicked the current mirror ball or current scan in PN.
• Same file can be added to the importing list sometimes.
• Thumbnail progress will be broken when removing a scan from add import file page
• Only first file is added to importing list for some fws file.
• Crash when register two rcp files which has more than one group during creation.
• Quick crash or export failed when exporting structured files.
