When I try to set a Coordinate CRS in ReCap (Studio), either through Preferences or within a project it gives me the following error:
Coordinate can't be applied successfully. Even after applying SP1 Update 1.0.100.12.
Why?
John,
I would first try to update your version fo ReCap. The latest is 1.4.2.2. You can get it by first downloading 1.4.0.132:
http://www.autodesk.com/products/recap/free-trial
The Autodesk Application Manager will then let you know that two updates are available to install. If you want to install them manually, they can be downloaded here:
Michael
