As per nvida detection my graphic card drivers are up to date but ReCap warning says drivers are not upto date how to overcome this warning/ problem both screen shots are attached
Thats not (exactly) the warning that ReCap is giving. Its asking if your card supports OpenGL 3.3. I would suggest looking at the specifications for the card, specifically which version of OpenGL it supports. As far as I know, driver updates will not change this.
I have tried my best to check that my graphic card Geforce 6600 support the openGL 3.3 or not but fail
Can u explain how to check it
Go to the vendor website and look for technical specifications. It will list the OpenGL version it supports. If you can't find it, contact them and request the information.
Geforce 6600 is an old graphcs card which doesn't support OpenGL3.3
We suggest you to upgrade your card to run ReCap.
I have the same error but am running an Nvidia quadro 2000 whose OpenGL is 4.3. Any ideas?
Have you updated your driver? we suggest you to go to Nvidia site and install the latest graphics driver.
Catherine
I am in the same boat. I have a AMD FirePro V5900 and I have the latest driver. It supports OpenGL 4.1.
Are we sure this is a graphic card issue?
-Kyle
