ReCap Pro General Discussion
Welcome. This is the place to share and discuss everything ReCap Studio.
Distinguished Contributor
100 Kudos
Post 1 of 17
Exporting issues - colour problem
320 Views, 16 Replies
09-18-2013 07:05 PM
There is something wrong with the Export process.
It doesn't matter which file format I go out to, it is messing up the RGB values in the resulting file.
You can see in the attached screenshots that some of the scan is correct, other parts are seethrough, and others are like static (noise) you would see on an analogue TV.
It also doesn't matter what file I use. They all produce the same result.
This is also consistent when linking into Revit and Navisworks.
Chad
Employee
11 Kudos
Post 2 of 17
Re: Exporting issues - colour problem
09-23-2013 09:30 AM in reply to: Brausmith
Hi Chad,
I assume this is more than one scan (RCS)?  Could you attach the RCP file for our reference?  I think this may be a known issue the team is working on.
Thanks for using ReCap Pro.
Ryan
100 Kudos
Post 3 of 17
09-23-2013 02:37 PM in reply to: ryan.frenz
It is just a single scan.
Attached is the .RCP file as requested.
Chad
Employee
5 Kudos
Post 4 of 17
09-24-2013 01:04 AM in reply to: Brausmith
Hi Chad,
It seems that you deleted some points in the RCP which may be the cause of export problem. Could you try to export the whole scan? You can create a new project with the RCS file in previous RCP's support folder.
Cloud Yao
100 Kudos
Post 5 of 17
09-24-2013 02:23 AM in reply to: cloudyao
That is indeed what I did.
I was doing some testing using the sample files before I jumped into something customised. With the warrior example I wanted to clip out the statue and do some testing in Revit.
I did as you said and the resulting exported .RCS file will all the points works perfectly fine.
From what you are saying it sounds like there might be a bug which needs to be addressed?
Chad
Employee
5 Kudos
Post 6 of 17
09-24-2013 02:35 AM in reply to: Brausmith
Hi Chad,
Thank you very much for what you did! We've already logged a similar bug:The points RGB value nearby selection for delete may be incorrect during exporting.
 But unfortunately I can't reproduce it now. Is it possible for you to attach the RCS file?
Cloud Yao
1 Kudo
Post 7 of 17
09-24-2013 03:07 AM in reply to: cloudyao
It was too big to upload here, so you can find the download on my 360 account.
http://a360.co/18Uxkt5
_____________________________
A2K Technologies Support Team
www.a2ktechnologies.com.au
Employee
5 Kudos
Post 8 of 17
09-24-2013 08:01 PM in reply to: a2ksupport
Hi Chad,
Thanks for sharing the exported RCS. You can change far plane to 50 or 100 for seethrough points. Could you also upload the original RCS file so that I can check how those noise points are generated.
Best Regards,
Cloud Yao
1 Kudo
Post 9 of 17
09-24-2013 08:33 PM in reply to: cloudyao
Here is a link for the original .RCS file.
http://a360.co/1696nYb
BTW, thanks for the time taken to look into this.
Employee
5 Kudos
Post 10 of 17
09-24-2013 10:00 PM in reply to: a2ksupport
Thanks for sharing the file. It's quite big. I'm downloading the file.
BTW, which version of ReCap are you using? You can get the version in the Control Panel->Programs->Programs and Features.
