I have 18 FLS files that I registered in Scene, created a project folder in Recap and imported. I have a lot of cleaning to do on the road (quite a bit of traffic passing during the scanning). Starting out I cliped an area, fenced off somepoints and deleted them. unclipped the pointcloud, found the next area I wanted to clean and repeated the deleting process. After about 20 or so iterations I noticed the reveloving circle and the message Please Wait. This period of waiting got longer and longer with each next deleting process to the point of a standstill.
I have looked on the forum re: slowing down Recap - created a unified scan - again satrted off well but similarly bogged down.
Is it caching points or data some where? I am at a standstill on the project and need to find a solution to why this seems to be a progressive problem.
I have cleared out all temp folder info, memory doesnt seem to be being stretched thin when looking at the task manager. If I re-start Recap - it pulls up the entire project fine and I can navigate around without a problem but as soon as I go to delete a few poitns - lock up.
Any thoughst or help would be very appreciated.
Regards
Andy
Unfortunately we don't have a good workaround at this time beyond what you've already tried. The engineering team is currently aware of the issue and is working on it with the highest priority. We will let you know when we know more.
I'm glad to hear you are working on this. I experience the same problem when creating regions. A couple of regions is fine but as I create more the project slows down dramatically, particluarly when I use the unclip all command. Is this part of the same problem?
The regions function could be awesome if only it would work for an actual project. My clients are impressed by the function when I demonstrate it but then I'm forced to tell them they can't use it extensively without bogging down the file.
I desperately need this to work as well. I have a client demanding that all demo'd utilities be moved to a region so that we can perform accurate clash against new design work. There is no way we can do this right now and are completely stuck in the mud....
I've been waiting 5 hours now for a limit box selection and point deletion operation to finish. I know it will finish, but every single additional point deletion operation keeps taking longer and longer.
indeed, i commented here about it
http://forums.autodesk.com/t5/ReCap-Pro-General/Recap-100-usage/td-p/5127046
the only work around i have at the moment, is region what you dont need - export to PTS then resume!
not the best workflow!!!
This will sound like a very weird solution but it has worked for me..... It appears that when you delete points the program stores the deleted points in your "clipboard" which bogs down the system as its saves all of the points you deleted (I can only assume so you can "undo" quickly if need be). When I clear my clipboard the system speeds back up and Recap no longer loads when I am cleaning up my scans. FYI... Windows 8.1 doesn't allow you to clear your clipboard anymore, so I open excel, put a single letter in a cell, copy it, paste it in another cell, and then jump back into Recap.
Very important note, you have to save and exit Recap fully before you attempt to clear your clipboard. Recap won't allow your clipboard to be cleared if its up and running.
Let me know if this works for all of you as it randomly did for me.
Hi THook,
the issue is still there, hopefully they get around to solving this soon. The ability to delete points is a major one but this issue makes the program unworkable.
The only way I could get around it was to export a RCS file and start a new project
I thought Autodesk might have sorted it out by now? Maybe by release 2.0 then...
I would advise SCENE users to do bulk editing there (removing points using scan point clouds 3D view) and export only slices of what you need to Recap. The only reason for me to import whole FLS files into Recap is to acquire the RCP format for insertion into Navis, far too much pain involved in doing serious editing there.
So... how does one empty one's clipboard...?
Also is there a way in the registry to limit the size of clipboard Recap uses?
I tried the clearing-the-clipboard method without any luck. Thanks for the tip anyway...
Autodesk, any update on the fix for this issue?
it was so validating to see this lengthy thread on an issue that has been giving me fits. Last night I totally ditched about 3 days worth of work and started over completely because the Recap file had become unworkable. One commenter mentioned that the file opens and navigates fine if closed down. That has not been my experience. Deleting trash and creating regions (a Brilliant tool if it worked) created LONG wait times just to select points, much less delete them and "unclip all". Even the act of opening this file that previously took 30 seconds to fill in ended up taking 30 minutes before I killed the program. That's when I decided to start completely from scratch. I now have only 3 regions created and I deleted only the worst trash.
Agree with another comment, that left unfixed, Recap is just a fomat changer from scanner-format to RCP - and not much more. Hopeful for a fix soon!
It's quite frustrating. There have been 5 or 6 updates to recap since this came up on the forum. Seems like it would be something they would address.
I've been checking in with the engineering team every couple of days on this and they're still very much working on it. Long story short, while it seems like it should be a simple fix, they uncovered some larger problems and decided to re-work a sizable chunk of the underlying code to help keep things like this from re-occuring down the road as scans continue to get larger and even more dense.
I know it doesn't make the problem any less painful, but I can assure you that we are focused on trying to make sure everything is done the right way rather than 'good enough... for now'.
