Hello, am a student at Chalmers University of technology and now aam using ReCap pro in my theses, am trying to move my work from a PC to another and what i understood from previous posts that i can copy the rcp file and also the rcs file which i used in the beginning, but what if i want to chose another rcs file instead with the same rcp file? is it possible? Right now am getting some problems when i use the program, my PC just acts weird everytime i do something, i even chose to work with a smaller area by editing the "show box" or what it is called? .. but does this even help? i mean the work am doing now only happen to the shown area in that boz right? if not, then what is the way to use so i can work just use a small part of an area to do my work and so on? am trying to just group my pointcloud in different regions so i can lately export every region on its own to Civil3D.
Wish to get an answer for my questions soon 😞
Another issue, my project just started regening really slow. You can see the scan regen in small tiles. As I try to move/pan around it starts the slow regen process again. It is pegging my CPU to 100% causing the RCP to work slow. I have been grouping my file in regions, tried to export to unified RCS but the regions didn't follow.. Any solution?
Also about changing the scan RCS file- how do you mean?is it under settings > advanced > search path for scan files? and just chose the file where my RCS file is located?
