ReCap Forum
Welcome to Autodesk’s ReCap Forums. Share your knowledge, ask questions, and explore popular ReCap topics.
Can files created in ReCap 2015 be opened by Autodesk 2014 products?
4 REPLIES 4
mike.burke
437 Views, 4 Replies
We don't have 2015 products installed yet and users have been asking for ReCap 2015.
Mike
Tags (2)
4 REPLIES 4
richiee
in reply to: mike.burke
Yes, everything should be backwards compatible. (If you did end up having a problem with anything, please let us know so that we can investigate if needed. However, that shouldn't be nessecary.)
mike.burke
in reply to: richiee
Thanks for the quick reply and info.
Cheers
Mike
ZoltanFerenczy
I am having a issue with this workflow.  I have created a point cloud using ReCap 2015 version 1.3.5.1 and I cannot load it into Revit 2014 build 20131024_2115(x64) Update Release 2.  I get an error saying "Unable to create a Point Cloud instance. The file may be incompatible or corrupt."
I don't use Revit, but....
1. Is it an RCS file you've output?  I'm guessing it is.
2. Does the PC you are trying to load into Revit load into a new Recap project?
    (That would be the first troubleshooting step to see if Revit has an issue or the PC is the issue.)
Rail Community
