Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
permanent deletion of of point clouds
is it possible to permanently delete points in recap. when i delete points and save and optimize, everything looks good until i open the file in navisworks and everything shows up again, can someone help me with that please
6 Comments
ryan.frenz
The next version of Navisworks should support this.  But you can also get rid of the points by doing a Save As and choosing the 'remove deleted points'.
-Ryan
dustinmanning
This also occurs within Autocad and Civil 3D. It's as if anything outside of Recap Pro disregards edits like deleting.
ryan.frenz
Yes, all products will disregard 'optimized' deletes until next year.
There are three ways to have your deleted points work in other products (2017 or earlier):
  • Don't optimize the project.  This will keep all the deletes as usual, and AutoCAD/etc should properly respect them.
  • Save As, and choose to 'remove deleted points'.  This gives you a new copy of the project with all the deleted points removed.
  • Export to unified RCS.  This gives you a consolidated RCS file for the project with all deletes removed.
-Ryan
ryan.frenz
This has been implemented in the ReCap engine and will be available in each product based in its individual schedule.  Should be no later than the next major release (2018) for each, possibly earlier.
For workarounds, see the comment thread or the ReCap community forum.
dustinmanning
Thanks for that Ryan. Somehow I totally missed the second option to 'remove deleted points'. Cheers!
VincentModena
The deletion of points still seems to be an issue.  It is fine to save as a unified RCS file but if you need to use the file for data extraction in other programs such as Pointfuse and Edgewise that require  scans that are not unified, the hard work of cleaning up the point cloud comes to nought.  Edgewise can now import Recap files but even "Saved As" files still bring in the deleted points. All of the points appear again and then auto pipe extraction is done on the entire point cloud.  Really frustrating.
Rail Community
Ā
Ā
