QuickCAD
*Hurst, Jeff
Message 1 of 3 (22 Views)
white solid pattern is black?
22 Views, 2 Replies
04-10-2000 03:01 PM
I'm trying to draw a polygon filled with white to place inside another
polygon. I pick white, but it fills black. Is there something I'm
missing? (QuickCAD Millennium)
*Smith, Harvey
Message 2 of 3 (22 Views)
Re: white solid pattern is black?
04-10-2000 03:20 PM in reply to: *Hurst, Jeff
Hi, Jeff.
If you're certain that your program is running correctly (not corrupted), then I
think the only way a closed polygon will fill with an opposite color pattern is
if the page is the same color as the fill AND you have the Invert Pattern box
ticked in the View>Options>Appearance screen.
Other than that...Hmm.
New Member
NH Steve
Message 3 of 3 (22 Views)
11-06-2004 07:32 AM in reply to: *Hurst, Jeff
I've got the same problem -- I cannot fill at all with white, so I created a color just off white, and that works until I save and then reopen my drawings -- then all the filled 'white' is black!! GRRRRRRRRRRR
Even symbols I have created with the slightly off-white.
This is driving me nuts, and I neeeeeeed to be able to use white fill!!!!
Please help!
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
