QuickCAD
*R, Paul
Message 1 of 2 (34 Views)
Tech Support-Quickcad splines and .dwg problems
34 Views, 1 Replies
02-12-2000 07:08 AM
Hi all,
I'm using Quickcad 6.0 and I've noticed that it doesn't import bezier curves
contained in .dwg files. The curve entities just aren't there at all when I
import a file into Quickcad but they are there when I load the same file
into Turbocad 5.0 or Autocad. When I export a drawing with spline curves to
a .dwg file from Quickcad and re-import that same file the splines have been
converted to polylines. This is a problem for me. I need the curves to
retain their properties as curves when I import/export to .dwg files.
Does Quickcad 7.0 properly handle the importing and exporting of
splines/beziers in .dwg?
Thanks.
*Support], Keith Sibbert [Autodesk
Message 2 of 2 (34 Views)
Re: Tech Support-Quickcad splines and .dwg problems
02-14-2000 01:04 PM in reply to: *R, Paul
I can't speak for beziers but splines in AutoCAD R14/2000 .dwg files remain
splines and the curves can be edited using Edit Vertices.
Keith Sibbert
PSG Product Support, Americas
WW Support & Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
Paul R wrote:
> Hi all,
> Thanks.
