QuickCAD
*Smith, Harvey
Message 1 of 2 (49 Views)
Sizing Rectangle
49 Views, 1 Replies
02-13-2000 03:34 PM
Ahmet.
In general, any time you want to size a object, use the Edit bar that appears
after you place it and input the values there, or use the 2D coordinate dialog
box.
For a rectangle, it's easiest to place the first point, then type or and
the dialog box appears. Input the leg dimensions in the x and y fields (use
[Tab] to toggle) an...
for instance. is
Relative,
is Absolute.
For lines, the Edit bar is best. Place the line, edit it on the Edit bar and hit
[Ent...
*Ayvaz, Ahmet
Message 2 of 2 (49 Views)
Re: Sizing Rectangle
02-13-2000 04:33 PM in reply to: *Smith, Harvey
Maybe this is a stupid question, but I can't figure out
how to size a rectangle.
I'm using a 1:5 scale and draw a rectangle which
should be 19"x36", but I get close at 19.06" x 36.03", etc.
I can't find a way to size this thing exactly.
Any help would be appreciated. I assumed the size would
show up on the toolbar, but instead it just shows a way to
size the width.
Best regards,
Ahmet Ayvaz
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
