QuickCAD (Read Only)
296 Views, 3 Replies
Rulers
While working on a drawing, I must have hit somethng that extended my rulers to +- 61000 inches. I always do my drawing on 8.5 x 11 pages, and the rulers are about -11" to 20". How do I re-adjust my rulers
3 REPLIES 3
Go to Tools>DrawingOptions and change the scale
back to 1:1 or whatever you had before.
Clues:
1. Always draw 1:1, use the scale change before
you print so the drawing will fit the page. Once
you determine the scale change necessary to fit
the page, then put that scale in your template
area of the drawing. Done.
2. Lose the Ruler. And the Page, too. Untick them
in the View>Options dialog box. You don't need
either for 99%+ of any drawings in process. Place
objects and entities in relation to one another.
All the tools are there for you to do this.
When it comes time to print, _then_ you can set up
the page and scale.
If you have any questions about details on those
two points, ask away. Someone may answer even.
Harvey
It's been 1":1" all along. Taking out the rulers doesn't help. If I try to move the drawing over a small amount by using the scroll bar, it goes off the page. With that large span on the ruller, clicking the arrows on the scroll bars moves it too much.
solved this one myself. Somehow a line of my text ended up about 10,000 inches away. I put the view in 'extent' and I noticed a little dot far away from my drawing. Zooming in onit, I saw it was a line of my text. How it got there, I have no clue. I deleted it and went back to my page and everything was back to normal.
Henry
