QuickCAD
QuickCAD
Active Member
0 Kudos
Post 1 of 1
Problem in viewing the file in millimeters
1295 Views, 0 Replies
07-13-2009 11:28 AM
Two more things. I go this drawing made in autocad in mm ( 1:1) and I want to view and change the drawing in millimeters with 1mm = 1mm scaling factor.
I open the drawing in Quick CAD 8 and in the beginning the QuickCAD asks me for what units do I want to open it with default option of inches.
I change the option to millimeters. Then the drawing opens up on the editing (white) area. Everything looks cool until I checked the drawing options in th tools menu. The units are still in inches. I chnaged the unit lenght in millimeters and the went to scale tab , and the scale tab is showing me the 1" = 15067 ". So, I changed the scaling option to 1mm = 1mm. And then tried to view the drawing but the drawing is off the white editing page. Can anyone advice what is really going on?
The second thing is that how can I edit or make changes to the text. I have also attached the file with the message. May be I am not converting the file into millimeters properly. Can some change the file into millimeters for me with the scale of 1mm = 1mm, so that I make changes to the drawing in millimeters. Thanks
Please advise!
John
