QuickCAD
*Wehmann, Alan
Message 1 of 3 (59 Views)
printer tray choice in Quick CAD 7
59 Views, 2 Replies
03-16-2000 09:15 AM
I have Quick CAD 7.0 (build54) installed on a Windows NT system. I
find it curious that File,Page Setup,Printer Page allows one to choose
a paper source & that this choice can't be overridden later on when
Print, Properties is used. Suppose one is not using the default
printer; how does Page Setup know what paper trays are available?
Until I realized that Page Setup was where the paper tray choice
should be made, I was rather frustrated that I couldn't make the
choice with Print, Properties--for the actual printer I had chosen. I
had wanted transparencies & kept getting paper.
Alan Wehmann
wehmann@fnal.gov
*Support], Keith Sibbert [Autodesk
Message 2 of 3 (59 Views)
Re: printer tray choice in Quick CAD 7
03-21-2000 07:34 AM in reply to: *Wehmann, Alan
Alan,
You might want to submit this a either a bug report or a wish list item at
http://www.autodesk.com/support/ then click on the desired link in the
right hand column.
Keith Sibbert
PSG Product Support, Americas
WW Support & Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
> Alan Wehmann
> wehmann@fnal.gov
*Wehmann, Alan
Message 3 of 3 (59 Views)
03-24-2000 12:46 PM in reply to: *Wehmann, Alan
Working with QC7 today and File,Page Setup,Printer Page I note that
one choice for Paper Source is "Use Driver Setting". With this choice
I seem to be able to later choose the paper tray with Print,
Properties when I go to print (actually I printed to file and then
looked at the PostScript file). It could be that when I had the
trouble described below, the Paper Source choice was not "Use Driver
Setting". Trying different perturbations convinces me that this was
the problem.
Alan Wehmann writes:
> Alan Wehmann
> wehmann@fnal.gov
Alan Wehmann
wehmann@fnal.gov
