QuickCAD
*Danny
Message 1 of 11 (136 Views)
Multiple scales on same drawing.
136 Views, 10 Replies
01-24-2000 05:51 PM
I was wondering if this was possible. Example: I have a plan view
of a foundation layout set at 1/8" scale and would like to show a
section-cut through a foundation wall set at 1/4" scale, all on the same
drawing. Can this be done in QC7. Maybe you can set different scales on
different layers...(not...
Thanks to all respondants
Danny
*Smith, Harvey
Message 2 of 11 (136 Views)
Re: Multiple scales on same drawing.
01-24-2000 06:30 PM in reply to: *Danny
Danny,
Check over in the AutoSketch newgroup for a recent post called "Convert", from
Al Najjar last Friday. In the thread are a number of ways to do this. If you
can't find the post, repost here and I'll copy it to you.
H
> Danny
http://www.westnet.com/~harvey/
*Danny
Message 3 of 11 (136 Views)
Re:
01-24-2000 08:05 PM in reply to: *Danny
Harvey,
I checked over at the AS ng like you said and read the post. What
they are talking about is scaling up ( or scaling down ) an already
drawn part of the drawing to create a detail view. What I want to do is
draw independant entities on the same drawing at different scales. For
example I would want something like the following to work:
Show an elevation view of a boat at 1/8"=1'0" scale and,
Show a cross section of the boat at, say, 1/4" = 1'0" scale instead.
...both views side by side ... both on the same drawing...and both views
editable with their respective scales.
I may be asking a lot from QC7 but I wonder if anyone has ever
accomplished to do this.
regards
Danny
Harvey Smith wrote:
> Danny,
> H
> > Danny
*Norris, Ric
Message 4 of 11 (136 Views)
Re:
01-25-2000 12:04 AM in reply to: *Danny
Hi Danny,
I am not exactly sure whether you wish to show the views after you have
drawn both elevations or have both views appear as you draw them.
AutoCAD/AutoCAD LT has an extremely powerful feature called
multiple/floating viewports and model/paper space which allows you to have
differently scaled areas of a drawing in an independant (although still
referenced) viewport. QuickCAD/AutoSketch unfortunately do not have this
feature.
From what you're suggesting, you ideally would like this feature....combined
with 3D capabilties.
Ric Norris.
"Danny" wrote in message
news:388D2112.3D52AD4D@videotron.ca...
> Harvey,
> regards
> Danny
> Harvey Smith wrote:
> > Danny,
"Convert", from
you
> > H
same
on
> > > Danny
*Coupar, Dave
Message 5 of 11 (136 Views)
01-25-2000 05:45 AM in reply to: *Danny
Danny,
You might want to try a "Detail View". Check Help for this topic then click
on the How To button. Works pretty good.
Dave
Danny wrote in message
news:388D01A1.DEC45027@videotron.ca...
*Smith, Harvey
Message 6 of 11 (136 Views)
Re:
01-25-2000 07:59 AM in reply to: *Danny
This is fine for showing the detail, but you can't edit the Detail View itself.
And if you move the position of the original drawing, then what you have chosen
to detail changes accordingly.
The Detail View should be used when the main drawing is finished and you have
decided what bits and pieces you want to show an enlargement of. Then you
Marquee those views and save them with appropriate names. Recall them, use
Detail View and place/enlarge them where you want.
I don't believe this command is what Danny is looking for. The feature he needs
may not be available in QC. But I've been wrong before.
H
Dave Coupar wrote:
> Danny,
> Dave
*Danny
Message 7 of 11 (136 Views)
Re:
01-25-2000 02:04 PM in reply to: *Danny
Harvey,
The feature I'm looking for is *not* available in QC7 but only on
higher priced Autodesk products ( I can't speak for AutoSketch though as
I'm not familiar with the product... ). For those of you who are
interested there is a simple way around my problem however. I'll try to
explain it concisely. Let's go back to my example that I stated earlier
about the ship...
What I want is ----> An elevation view of a ship at 1/8" scale and,
----> A section view of the ship at 1/4" scale.
...both on the same drawing, and both side by side.
What I suggest you do is:
a.) Draw both views at 1/8" scale and finalize the drawing this way,
then,
b.) Explode all the dimensions in the 1/4" view so that the text and
dimension lines become seperate entities ( This will effectively end
*all* associative dimensioning during scaling up and scaling down
operations )
c.) Reduce all the text height by half in the 1/4" view.
d.) Reduce the terminator size of the dimension arrows by half in the
1/4" view.
e.) Select all the entities in the 1/4" view
f.) Use the Scale button to scale up by a factor of 2
et voila, the 1/4" detail view magically appears with arrow sizes and
text sizes matching those in the 1/8" view. Correct dimensions and all.
bye to all
Danny
note: steps c.) and d.) could also have been done in step a.)
> H
*Norris, Ric
Message 8 of 11 (136 Views)
Re:
01-25-2000 02:12 PM in reply to: *Danny
Ahhh....now I understand...!!!
news:388E1DF6.734ED2F0@videotron.ca...
> Harvey,
> about the ship...
> then,
> operations )
> 1/4" view.
> bye to all
> Danny
itself.
chosen
have
you
use
he needs
> > H
*Smith, Harvey
Message 9 of 11 (136 Views)
Re:
01-25-2000 03:37 PM in reply to: *Danny
Danny,
That's what is affectionately known as a workaround. This particular one appears
to be quite a PITA, though. Wouldn't it be nice to have the capability of
placing two entities on one drawing page, each with its own scaling?
But I'm glad to know that I wasn't wrong yet again. However, we haven't heard
from Paul yet. He could surprise us, but I'll bet you an alligator suitcase he
won't come up with anything.
H
Danny wrote:
> Harvey,
> about the ship...
> then,
> operations )
> 1/4" view.
> bye to all
> Danny
> > H
*Norris, Ric
Message 10 of 11 (136 Views)
Re:
01-25-2000 03:48 PM in reply to: *Danny
Hey Harvey.....what's a PITA...???
"Harvey Smith" wrote in message
news:388E33BF.D4157DAE@westnet.com...
> Danny,
appears
heard
suitcase he
> H
> Danny wrote:
> > Harvey,
> > about the ship...
> > then,
> > operations )
> > 1/4" view.
> > bye to all
> > Danny
View itself.
have chosen
you have
you
use
he needs
> > > H
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
