QuickCAD
*MonkeyJump
Message 1 of 3 (28 Views)
ellipses in QC7
28 Views, 2 Replies
02-14-2000 02:56 PM
When a narrow ellipse is drawn and you zoom in at one of the narrow
ends, it is quite visible that the ellipse is drawn using straight line
segments. I decided to check to see if internally the ellipse was
defined precisely, so I drew a line through one of the ellipse's
straight segments and tried to snap using the intersection snap. When I
did this, the autosnap snapped to a point outside of the straight-edged
ellipse at a point that was "theoretically" on the ellipse. So in effect
we have QC7 drawing ellipses ( I imagine circles included ) using
straight line segments to the screen, but internally treating them using
precise function definitions. Nice to know. Now I just wish I knew how
splines and fitted curves were treated internally too.
*lscad
Message 2 of 3 (28 Views)
Re: ellipses in QC7
02-14-2000 03:40 PM in reply to: *MonkeyJump
Tools-Drawing Options-Drawing-Ellipse Segments (#bet. 3--1999)
*MonkeyJump
Message 3 of 3 (28 Views)
Re:
02-14-2000 05:05 PM in reply to: *MonkeyJump
ya............so?
Did you notice the mistake in QuickCad7 ? The help message for
"Tools-Drawing Options-Drawing-Ellipse Segments" states:
To change the number of segments used when converting an ellipse to a
polyline/polygon, type a number in this box. The default number is 36.
Lower values result in rougher polygons, but they redraw faster and
require less drawing memory.
.... when in reality, it should read:
CURVES, type a number in this box. The default number is 36. Lower
values result in rougher polygons, but they redraw faster and require
For some reason or other, when you convert an ellipse to a
polyline/polygon and then explode it you always get 16 polyline
segments, regardless.
Post to the Community
New Post
Need installation help?
