QuickCAD
QuickCAD
New Member
0 Kudos
Post 1 of 6
Convert Drafix .cad file to Autocad 2010.. need help
5460 Views, 5 Replies
08-16-2009 12:48 PM
I have some old .cad files I would like to re-use. They were last saved in 1997/1998 with .cad file extension. I think I was using Drafix but not sure. Can anyone convert for me? (File attached)
Jack
New Member
0 Kudos
Post 2 of 6
Re: Convert Drafix .cad file to Autocad 2010.. need help
01-19-2011 05:10 AM in reply to: jgutsch
Hi don't have a solution to conversion yet, but can tell you that your file was created in Drafix:
February 15, 1996
Drafix Windows CAD
IBM PC
DOS 3.0
MS 2.1
1989 Foresight Resources Corp.
Best of luck.
Member
1 Kudo
Post 3 of 6
02-08-2011 12:27 PM in reply to: jgutsch
I have an old copy of Drafix running I will try to download the file and convert it an Autocad file.  Where can I contact you off the borad?
John Davis
Member
1 Kudo
Post 4 of 6
02-08-2011 12:36 PM in reply to: johnsdtn40
I was able to convert it to a .DWG and a DXF file  I hope it helps.
John Davis
New Member
0 Kudos
Post 5 of 6
02-08-2011 08:44 PM in reply to: jgutsch
For information:
I think that AutoSketch 10 has included the facility for opening old Drafix files. Once open you can save as AutoCAD .dwg.
Glad you got it sorted.
Active Member
0 Kudos
Post 6 of 6
09-29-2011 01:57 PM in reply to: johnsdtn40
Hello John,
Was wondering if you could convert a few files for me.  I have run into these .cad files also and can't find anything to open them short of spending $150-200 and they just aren't worth that to do it.  If you could I would really appreciate it!
Patrick
P.S. I'll attach them later if are willing.
Thanks again!
